AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Beam, Join tools, change reference
1 ANTWORT 1
Nachricht 1 von 2
406 Aufrufe, 1 Antwort
Is there a way to change the DEFAULT beam join reference? For example, when putting a beam between two colums the DEFAULT reference is on the  edge of columns, so the beam does not reach the centre of the columns (same thing is with walls). Then You can of course change the reference manualy, but it's a lot of work to be done...
The idea is to have an join reference in the centre of the column for egzample, or in some particular distance from the centre instead on the columns edge.
Anyone?
Kind regards!
Bartek
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
If you want the beam starts and ends @ center of columns, then make the columns lower than the bottom of the beam.
In Foren verƶffentlichen
