Beam Features missing on IFC Import
2 ANTWORTEN 2
Nachricht 1 von 3
Julio_Soto
214 Aufrufe, 2 Antworten
I'm importing an IFC model and I noticed some cuts did not show up. When I open the IFC model in any other open source IFC View the beams are displayed correctly. When I open it in Revit it's missing the top cut.  This is the first time using Revit to open IFC models. Is this typical for Revit?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Julio_Soto
What's cutting it?
Nachricht 3 von 3
Julio_Soto
als Antwort auf: barthbradley
It was exported from Advance Steel. Advance steel uses a beam shorting feature.
I also just noticed that in Revit the steel bracket at the top is shifted over and conflicting with the column. sigh :enttäuschtes_Gesicht:
