Hello everyone,
I drew a beam system. In a section (not exactly perpendicular to the beam system). Some beams appear but others don't. Beams all are parallel to one another. Any clue ?
Raphael
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi Toad,
Is it this parameter you're refering to ?
I unchecked it but it didn't work.
Can you attach the file?
So some beams are partially obscured by the floor because they overlap? If they don't overlap then you have something like the below image? Would that work?
Beams do overlap with the floor above. What I would like to get is the YES picture (made with detail elements). What I get is the NO pic.
@ToanDN wrote:So some beams are partially obscured by the floor because they overlap? If they don't overlap then you have something like the below image? Would that work?
You can fix this by
@halfon.raphael See GIF Below - Use the attached Beam family
You could edit the beam family and set the 3d extrusion to be visible for all detail levels (coarse, medium, fine), reload,
then Join geometry the floor with the beams.
unfortunately I'm using Revit 2019. Can't open your file. What did you change in your file "Chevron NEW" ?
A 2018 version of the family is attached to previous post
It's weird : doesn't want to open in 2019.
My beam family (which I changed to draw the X when cut) has the 3D extrusion visible for all detail levels. But Revit still says "unable to join"
Redownload the new family...the previous was 2022 ...replaced with a 2018 it should open in 2019
