AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Beam cut back in coarse detail level
2 ANTWORTEN 2
Nachricht 1 von 3
458 Aufrufe, 2 Antworten
I have drawn a beam member whilst in the coarse detail level, I get a small line perpendicular to the member only at the beginning of the beam member. can anyone help how to remove this small line? I have also attached a picture :Capture.JPG
Tags (3)
2 ANTWORTEN 2
Nachricht 2 von 3
dzanta
als Antwort auf: Anonymous
can you give me more information?
horizontal beam is what type, usage?
is it connected to something on the left side
is it the standard beam in Revit or a custom one
can you edit the family to see if this is an object set to display in Coarse Level only?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 3
cbcarch
Try this:
VG>Model Categories>Structural Framing>drop down menu>turn off "Stick Symbols"
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
In Foren verƶffentlichen
