Beam/Column join doesn't work when beams have different types.
7 ANTWORTEN 7
Nachricht 1 von 8
ysautodesklover
2823 Aufrufe, 7 Antworten
Dear Revit Users,
I found it is inconvenient Beam/Column join doesn't work when beams have different types.
I was trying to join two typed precast concrete beams and couldn't join two beams like I wanted below.
How do you handle if you wanna do the same?
I would appreciate your any advise.
Thank you in advance,
Yuki
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: ysautodesklover
Edit the family and change the material for model behaviour to other.
Nachricht 3 von 8
Corsten.Au
Corsten
Building Designer
Nachricht 4 von 8
ysautodesklover
als Antwort auf: ToanDN
I tried that way, and Beam/Column join became available.
However, I could not join the two beams as I wanted.
See the left that two different types have been set as "other" and right as what I wanted to do.
Nachricht 5 von 8
ysautodesklover
als Antwort auf: Corsten.Au
Thanks!
It is a new idea to join beams for me but it doesn't work for my case.
Nachricht 6 von 8
I see.  If you have two different types you need to cut them using a reference plane.
Nachricht 7 von 8
ysautodesklover
Oh, how did you cut by using reference plan? With a void?
If you mind, please give me little more instructions.
Yuki
Nachricht 8 von 8
Yuki
Very simple:  draw the reference planes where you want the cut to happen; stretch the beam to fully pass the plane;  Cut geometry, select the beam, select the plane, then BAM.
