Is it possible to have the resolution settings and compression settings saved and then with a click of a button automate the Revit Export Walkthrough process?
Right now, the user has to navigate through the R command drop down menu, hover over the Export option til the sub menu expands, scroll down to Images & Animations before finally being able to select Walkthrough. Then in the Length/Format window, the Format like Visual Style, Rendering dimensions still have to be selected. Even after clicking OK, the user has to find a location to save the walkthrough file and lastly choose the compression format.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
