Batch Rename Views
8 ANTWORTEN 8
Nachricht 1 von 9
curryspice
283 Aufrufe, 8 Antworten
Batch Rename Views
Looking for a way to batch rename views, by replacing terms, or add prefix/sufix. There is an add-in from BIM soft Solutions that does exactly this but I can't get it to install. I've reached out to support, but with no reply.
https://apps.autodesk.com/RVT/en/Detail/Index?id=1299788089247576718&appLang=en&os=Win64
I know you can do this in Dynamo but I'm still unfamiliar with this so I would prefer an add-in.
Any suggestion would be appreciated. Thank you.
Tags (3)
Beschriftungen (3)
8 ANTWORTEN 8
Nachricht 2 von 9
Simon_Weel
als Antwort auf: curryspice
And why can't you get it installed?
BTW - there are more apps. This one seems more capable: Magic Rename Tool | Revit | Autodesk App Store
Nachricht 3 von 9
curryspice
als Antwort auf: Simon_Weel
Hi, thank you for your prompt reply.
I don't know why it doesn't install. The installation does run, but there is no add-in tab or app button.
Looking now at the suggested app. Many thanks! :leicht_lächelndes_Gesicht:
Nachricht 4 von 9
curryspice
Well, this add-in also didn't install which leaves me to suspect it's a different issue...
Nachricht 5 von 9
TripleM-Dev.net
Which Revit version are you using?
Nachricht 6 von 9
curryspice
als Antwort auf: TripleM-Dev.net
2025.3, and that is probably the reason why these add-ins are not showing up in the ribbon.
Nachricht 7 von 9
Both DiRootsOne and PyRevit have view renaming tool.
Nachricht 8 von 9
TripleM-Dev.net
The first addin you mentioned is only supported up to R2024.
Revit 2025 is a big update in API sense, so I think a lot of addins will take some time to have R2025 support.
Nachricht 9 von 9
curryspice
als Antwort auf: ToanDN
Hi @ToanDN, true! I use DiRoots One for parameter management and never actually looked into the other tabs... Waiting for my licence  no. to be delivered.
pyRevit is a no go. I get an error on uploading. Will try to fix in the future.
For the record, I also found https://nonica.io/  which appears to also to the job.
