Batch pdf printing
Batch pdf printing
Batch pdf printing
Is there a way to batch print to pdf with auto file naming?
What I need to do is to print all the sheets, (around 100) to individual pdfs. Thus, I do not want to name each one individually.
How would one go about this? Is there a plugin that I don't know about?
rudi.roux
Hi @Anonymous,
Hope you are well! Smiley Happy
Have a look at the following two links below which served as a solution for other users:
Link ONE
Link TWO
Also, other paid for options are RTV Xporter  OR  Xrev Transmit (This one is generally also the favorite option among past forum threads, apart from batch plotting, you can batch export & filter what you want to plot/export to .DWG etc.)
Other options like BlueBeam can also be investigated.
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Hi Rudi, thanks for the links, but those also require you to name each individual file. Any one of our big multi use projects will have upwards of 100 sheets per package. Having to name them individually is not an option.
rudi.roux
Hi @Anonymous
Quick extracts from what RTV Tools/Xporter and Xrev Transmit where you can use project parameters on sheets or from your Project to name PDFs/Batch PDFs.
Rudi Roux
LinkedIn
Archigrafix_Norge
Archigrafix_Norge
Among many other features Docuflow takes care of all the complicated stuff in making PDFs.
  • Creates correct PDF page sizes that matches the Revit sheets. Any size, any format.
  • Prints landscape and portrait sheets at the same time.
  • Filename customization
  • No dialogs prompted during the print job.
  • Sorts your sheets by last project revision (Revit sequence). One can easily find the latest sheets on top of the list.
  • Optimized for speed. According to our tests, the fastest batch printer of PDFs for Revit.
A free trial of Docuflow can be downloaded in the Autodesk Revit App Store:
Luis Santos
archi systems as
Archigrafix_Norge
Here goes a short presentation of how to batch print with Docuflow.
Luis Santos
archi systems as
