Hello
I have a curtain wall (Name: Facade - CURVED) with Basic Wall (Name: GLASS WALL) as a Curtain Panel.
The issue I have is that I can't control the Object Style for that curtain wall, that is the line weight in projection. It's too thick and different than the lines for the system curtain panel.
In the screenshot provided, the otlined corner elements with thicker black lines are the curtain walls with Basic wall as a Curtain Panel. In between with gray color is curtain wall with system panel as curtain panel. In the background, black lines for the mullions.
Is it possible to control the line weight for the aforementioned curtain wall?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Why are you using a Basic Wall as a Panel instead of a System Panel? What is it you trying to accomplish?
Howard Munsell
