I've got my base point and survey point. I want to move them vertically in my model (or move my model vertically).
When I move either of them vertically (in both clipped and uclipped modes) - they change nothing. The same goes for Relocate - it acts like it's relocating (processing time) but doesn't. My levels stay the same as before the moves, both when reading off from "survey point" and "project base point".
I created a new blank model to test my understanding, by moving around the points. It works as expected reading off the location of the points, but I could not replicate this in my model!
Thoughts?
Gelöst! Gehe zur Lösung
I think I figured it out partially. I have a spot elevation crosshair tag that says it's reading survey, but it appears to be reading from "Relative Base: Current Level" under its constraints?? I tried to edit the spot elevation tag family but it might be a system family.
Figured it out, the Spot Elevation Tag has 3 modes, "Relative, Survey, and Project Base Point". I was using it to verify survey, but in its type parameters, it was reading out "Relative". It appeared that the true survey heights weren't changing.
