I am sure this must have been raised before as it seems like such a common occurrence. However:
Can someone explain how to stop this happening?
I have unlocked the external layer of the wall so that I can raise it above DPC level, see below:
However, when perpendicular walls meet which have this feature they do not join properly (not if the Base Extension Distance is the same for both walls), see below:
Results in this in plan view:
If you change the base extension, so that each wall has a different value, you get this:
i.e. correct joining.
Unfortunately, in elevation you end up with this sort of thing happening:
I have tried changing the material priorities within the wall, but it doesn't seem to make any difference.
Any help would be greatly appreciated.
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von tom-common. Gehe zur Lösung
I suggest creating parts or modelling each layer individually for more control
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Are you talking about this:
BTW: We model walls with base extensions in every project. We have no issues.
If find changing the wall join to Miter allows walls of this sort to cleanup better.
Steve Stafford
