Baluster thickness problem
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Piotrek18
379 Aufrufe, 2 Antworten
Hallo all,
I've got a problem with baluster thickness - as described on picture. The problem is with steel posts 40x20mm. When Railin is sloped - dimensions are OK, but when part of railing (or new one) is paralell to ground the thickness of posts differ and they showing wrong value. There is invisible line in the posts, that dimensions snaps, and show right value, but the model is wrong.
Any help?
thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
cyrankam
als Antwort auf: Piotrek18
Seems like an issue with the baluster family, could you upload that? If not make sure the constrains are working correctly when the slope angle is set to 0. Also good practice is to model the geometry using sweep with external profile rather then extrusion.
Nachricht 3 von 3
Piotrek18
als Antwort auf: cyrankam
Thanks, thats true. It was extrusion made with one piece. I've changed it to include some void cuts.
