Baluster Count
20 REPLIES 20
Message 1 of 21
4241 Views, 20 Replies
Baluster Count
Does someone knows how to count in a schedule the amount and size of baluster I have in my file??   I had been searching and I didnt find anywere on the web.  I will appreciate your help.
Tags (2)
20 REPLIES 20
Message 2 of 21
dzanta
create a calculated value parameter as a formula (length/0'-4").  Use the baluster spacing to determine the denominator value.  See image.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 21
guillermo4JEUL
Hi, is there now a way to schedule the baluster amount?
I would like to know if there is a way to get the count of baluster without the formula, because I have several types of railings, with some complicated situation where the formula does not give me accurate amounts including different types of baluster in the same railing, so I want to schedule them by type in order to buy the amount enough of each type. So it could save me hours of work if I can get the count of baluster by type.
Thanks!
Revit 2019.2, Windows 7
Message 4 of 21
in reply to: guillermo4JEUL
How about nest a shared generic model family (without any geometry) in the baluster family and schedule them in project?
Message 5 of 21
guillermo4JEUL
in reply to: ToanDN
That sounds like an Idea, I'll try that!
Thanks!
Message 6 of 21
It doesn't work.  Don't waste your time.
Message 7 of 21
guillermo4JEUL
in reply to: ToanDN
ohh, Thanks!
Well thanks anyway, for this time I'll make a mix between the formula and manual count, just to get the job done, but if anyone came with an idea please share for future circumstances.
I appreciate your help and time ToanTD.
Message 8 of 21
augidomeo
in reply to: dzanta
Oh no formularOh no formular
dotuanhanh.blogspot.com
Message 9 of 21
ebpavan
Not only baluster is impossible to be counted without tricks, but also handrail and railing profiles total length. (edited)
Message 10 of 21
ebpavan
in reply to: ebpavan
If someone could point this issue out to Autodesk for an update, it would be great. (edited).
Message 11 of 21
augidomeo
https://forums.autodesk.com/t5/revit-architecture-forum/revit-wishlist/td-p/5306169
we had many writers: "desire"/"dream of great features"/"plead for this repair"...
i expressed to adsk, maybe i wrote each other with you: "desire"/"dream of great features"/"plead for this repair"...
Again!
Message 12 of 21
syman2000
There are lots of user requesting to fix the railing and stair tool. I agree they are broken and require a lot of workaround. I wish autodesk will finally put a real effort to fix the existing tools and revamp it for upcoming release rather than stick to old tool that haven't update for over a decade. Just support the ideas and comment on it. Hope Autodesk finally listen to their users.
https://forums.autodesk.com/t5/revit-ideas/a-stair-tool-that-actually-works/idi-p/9658526
Message 13 of 21
As a workaround you could use supports as balusters and schedule those.
Message 14 of 21
Found this alternative using Dynamo... haven't tested it, just thought I'd drop it here aswell...
Message 15 of 21
in reply to: martijn_pater
Add a shared generic family with a name and no geometry to the baluster family. Then schedule it in project.
Message 16 of 21
martijn_pater
in reply to: ToanDN
Didnt you suggest the same in post 4 and then came to the conclusion in post 6 it didnt work? 😄
Message 17 of 21
Did I?
Message 18 of 21
martijn_pater
in reply to: ToanDN
Lol I don't know 😐 you got me all confused, is it different?
Message 19 of 21
assyhassan_ha
Isolate the Railing category in 3D View, export it to DWG, and in AutoCAD select All, Explode All.
Now, you can select any Type of Balusters and with SelectSimilar & CTRL 1 It is done.
Message 20 of 21
DoHungNam
Great!
Forma Design Contest
