Bad shapes of imported cad in revit
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
pawel.kS3DHM
1439 Aufrufe, 2 Antworten
Hi, i have a problem with link autocad draw. I linked a autocad draw with to attached xref. (picture below)
I links autocad draw in revit with normal options (picture below)
but after import i get something like this (picture below)
circles in autocad, in revit lost shapes... Do you know how to fix it? Thanks in advance!
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: pawel.kS3DHM
@pawel.kS3DHM
  1. Make sure it is not outside the 10miles radius
  2. Clean up the DWG before bringing it in
  3. AND - Uncheck the option Correct Lines that are slightly off axis
Nachricht 3 von 3
pawel.kS3DHM
als Antwort auf: RDAOU
Thank you for answer but it didn't work...  i tryed other way and i used bind option on xref. Then i use explode option. Now the shapes are ok :leicht_lächelndes_Gesicht:
If you know technicaly why this works pleas answer. I want to know
