I have a rather simple question, I need backlighting on a wall, this wall is outside, its a screenwall so you can see through it, I need it set near the top of the wall pointing down, I know I can edit how the light shows, problem I am having is finding the right kind of light and for it to look good as it creeps down to the ground.
So what I am asking is if anyone can give me some lights to use. I am using Revit '15 or if they know of the perfect seting to change the lights to. I am using wall pack light.
Thank You!
Dear, I have posted you a family that you can use which i made some time ago,
It's a strip of lights wall based family, just place it on the face you want and it will light up everything you want ![]()
Tell me if this works with you
BUT NOTE IT WORKS WITH REVIT 2016 and 2017 , not 2015
Is there a way to change the light color by chance? I have tried everything I can think of and can't figure it out.
