I have had background processes running for over 2 days causing me unable to save my file. I really need someones help here. I already turns off all of my family system properties calculations off as per another thread.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
I see that you are visiting as a new member. Welcome to the Autodesk Community!
If this is a windows background process,
If not, Can you specify more details? Are you running a rendering? What is the Revit version/ A360, server, central model?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
How long did you work in your last session ?
You can try killing other unnecessary processes and set the priority of the revit process to high .
If the answer helps , please kudo and accept as solution.
