I have a problem in my template, when I create a new drafting view the background color is always beige and not white. With the default Autodesk template, it's white. Do you now how to change this (I join the template) ?
Thanks a lot, ![]()
Gelöst! Gehe zur Lösung
Hi fafa007,
Thank you for contributing to the Autodesk community. It is always a tremendous help to make as much knowledge as possible available for everyone to find.
I understand you are looking for instructions on how to change the background color in Revit.
Here are some helpful links explaining how to adjust different color options:
Please feel free to let me know if you need anything else and I will be more than happy to help.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I discovered the problem. There was on the drafting view an elevation drawing template that had a background. The drawing view takes on the color of the soil.
Some kind of bug?
I saved the template in the attached file.
Thanks for your help.
