I converted the .rvt file to .nwc, however, I don't want the axes to be exported to navisworks, example in the photo: What should I do to not export the axes?
can you hide those lines before exported to nwc. thanks
there are many axes at different levels, I can't find them all. This is not a viable solution.
you can hide from your VG and create a view template to apply in every view or share your file here so we can check?thanks
on second thought it could be come from your loaded families? if yes try to edit your family and delete from there and see if helps. thanks
Did you click off Show Grid?
result no grid
