automating architectural drafting process
10 ANTWORTEN 10
Nachricht 1 von 11
mmegc
488 Aufrufe, 10 Antworten
i heard that Microsoft partner with autodesk and microsoft created a power package for automating revit work flow. is that true? what does the power package include if yes?
i myself want to automate the process of dimensioning entire architectural floor plans.
i also want to automate the process of placing 2d detail items components family in certain rooms of architectural floor plan in revit 2023.
finally, i want to automate the process of placing multiple rooms and room names and placing of room dimensions in architectural floor plan.
Is there also any add on software for revit 2023 which allow users to automatically create many options of architectural floor plans based on the fixed locations lengths of exterior walls of a single family house? Also automatically generate many options for elevations once the exterior walls locations and lengths are specified?
please kindly help if possible.
thanks, gideon
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: mmegc
This?
Nachricht 3 von 11
Is this what you're referring to?
 https://blogs.autodesk.com/revit/2022/04/29/revit-2023-automate-workflows-using-revit-data-with-micr...
If so, I see nothing in that one-sheet the suggests anything like you're describing.  Automating the process of dimensioning entire architectural floor plans?  Sounds fantastical.
Nachricht 4 von 11
mmegc
als Antwort auf: barthbradley
thanks for the link.
it helps but automating creating of floor plans and elevations. i need to use dynamo to create own codes.
thanks, gideon
Nachricht 5 von 11
When you say "automating creating of floor plans and elevations", what do you mean exactly?
FWIW:
Project Templates | Revit | Autodesk Knowledge Network
Nachricht 6 von 11
Please share the codes here when done.
Nachricht 7 von 11
als Antwort auf: ToanDN
I think the OP is planning our demise, @ToanDN.  If the OP is successful, then we're all at out a job. :zwinkerndes_Gesicht:
@mmegc: if your "source code" actually works, I want to be an early investor.
Nachricht 8 von 11
aRcHiTeCt.JM
@mmegc
this company is going that way
https://www.evolvelab.io/software/glyph
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 9 von 11
mmegc
als Antwort auf: aRcHiTeCt.JM
thanks for the link
Nachricht 10 von 11
mmegc
sorry, to be honest.
I tried to learn dynamo before, but i think the goal i set for these tasks are too high for me or take me a very long time to figure out
Nachricht 11 von 11
mmegc
i meant:
for example, based on the provided room size and number of rooms and or other architectural design factors. the revit add on can generate the layout or floor plans based on the basic information provided by the customers. assuming the exterior walls locations and length are given.
similar concept can be applied to the elevations.
does it clarify your questions?
