Automatically generating floor finishes with Room boundary By Dynamo
DFcheee
DFcheee
Hello Friends,
I generate a code that is going to create floor finish type from room boundary and it worked.
I want to master it by including the space bellow doors and picking the floor by door swing.
It started showing some warnings.
If someone is able to look at it I will be really glad.
Thank you in advance.
Lance.Coffey
Autodesk Support
Autodesk Support
Hello @DFcheeeI’m seeing that you also posted this question on the Dynamo BIM forum here: Finish floors from room boundary include area under door
That forum is more focused on Dynamo, so would be a better place for such questions. Did Marcel_Rijsmus reply directing to the thread Selecting doors and windows from room X to room Y lead to a solution?
Lance Coffey
Technical Support Specialist
DFcheee
@Lance.Coffey  Still getting some nulls dont know why I cant combine both scrips.
I do like my base, cause I can extract more info from it and it does it for the level.
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the update @DFcheee!
As Marcel noted (in the Dynamo thread), the missing packages do look like they are from Data-Shapes.
Have you tested installing this package?
Lance Coffey
