Howdy ACE friends...
Is there a way to have columns adjust their height between the top of a sloped floor, and the flat floor above?
I need the massive replication of this to, hopefully, calculate individual heights of pedestals, for a pedestal paver assembly. Open to other ideas on achieving this.
-Bryan
Gelöst! Gehe zur Lösung
What material are your columns? Steel, concrete, wood or something else?
Initially a couple tactics come to mind:
@Redrunner92 thanks for your reply. I've decided to look at this from another angle. Using dynamo I have been able to place points on surfaces, which can be exported. From Dynamo the XYZ coordinates can than be used with a little calculus to derive the information I needed.
