Automatic Ceiling tool not working
15 ANTWORTEN 15
Nachricht 1 von 16
tstewart
785 Aufrufe, 15 Antworten
Automatic Ceiling tool not working in 2023. How to draw SAT ceilings automatically?
15 ANTWORTEN 15
Nachricht 2 von 16
jay_colcombe
als Antwort auf: tstewart
Can you confirm your Walls are Room Bounding in the Properties Palette
and the Ceiling Height is lower than the Wall Height
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 16
hmunsell
als Antwort auf: jay_colcombe
to piggy-back on @jay_colcombe .... are you sure your ceiling is Below the top of your walls. if you place your ceiling at the same elevation as the top of the wall, it will go over the top.
Howard Munsell
Nachricht 4 von 16
hmunsell
also, depending on what version your running, make sure your walls are not slanted.
Howard Munsell
Nachricht 5 von 16
tstewart
Wall hts are 14' and Ceil. hts. are 9'. All walls were drawn in plan and show on the Reflected Ceiling plan.
Nachricht 6 von 16
tstewart
als Antwort auf: hmunsell
Revit 2023
Nachricht 7 von 16
jay_colcombe
If you select a Wall is there a Tick where is states Room Bounding in the Properties Palette?
Jay Colcombe
Nachricht 8 von 16
hmunsell
are the walls set to Vertical? if set to tapered or slanted you cannot place an automatic ceiling.
Howard Munsell
Nachricht 9 von 16
tstewart
The walls are vertical and there is no "tick" where it states "Room Bounding."
Nachricht 10 von 16
jay_colcombe
This is the issue, if the Wall are not bounding they cannot automatically define the boundary for the ceiling
Jay Colcombe
Nachricht 11 von 16
tstewart
Bounding is checked in Properties, so should it be unchecked?
Nachricht 12 von 16
jay_colcombe
The Walls create the perimeter for the ceiling so the Walls need to be room bounding “Ticked” in the properties palette for the walls.
Room bounding for the ceiling means the ceiling is used as the top of the room (box) rather than the floor above.
Jay Colcombe
Nachricht 13 von 16
hmunsell
would you be able to upload the file for us to look at?
Howard Munsell
Nachricht 14 von 16
tstewart
FYI
Nachricht 15 von 16
jay_colcombe
Nothing attached?
Jay Colcombe
Nachricht 16 von 16
jay_colcombe
For Clarity,
4 Walls all room bounding above the height of the Ceiling level
Ceiling Automatically detects bounding elements and will be created
If there is no full boundary no Ceiling cannot be automatically created
This would require manually sketching the boundary of the ceiling
Jay Colcombe
