Autodesk Viewer not displaying the linked CAD file linked in a revit model
2 ANTWORTEN 2
Nachricht 1 von 3
475 Aufrufe, 2 Antworten
Hello everybody, hope you are all fine.
I'm new to autodesk viewer, when i found it i imediatly fell in love with it, and wished to use it in every single project i would do from now on.
I'm facing a problem in wich i have an electrical projected designed on revit  with a linked architecture model in a CAD file.
I uploaded both to autodesk viewer. But the architecture seems corrupted.
When i use it in revit i see no problems... But on autodesk viewer the problem seems to occur.
Can anybody please help me to understand what is happening or if there is a solution for the problem?
Thank you all in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Why don't you use the Revit Viewer instead?  It doesn't appear as a shortcut on the desktop, but does in the applications list.  Just search for Revit Viewer application list.
Nachricht 3 von 3
I don't think Autodesk Viewer can handle links in the model.  If you want to show them you need to bind them.
