I installed revit 2016 from here to my Dell Precision M 4700.( Intel I7, 2.80Ghz, 32GB RAM -nvidea quadro k2000M)
It took some time but everything went ok.
However, when I execute the software, windows 8 pro opens an image and a message saying "revit is not responding"
I unninstalled, and installed again, Ive tryed to install an older version and always the same response appears.
Have you have any ideia of what could be going on?
Flavio
Hi Flavio,
Thank you for taking your time to post this on the forum,
I would most likely as a first check, go to NVIDIAs webpage and run their driver update client.
Have you always had this issue with the machine or has it started occurring recently?
In addition if you haven't already, check the Desktop App for available updated. It's really important that you run the latest release as we not only send out improved features but also make it compatible with the updates that are sent out with Windows.
