You are going to have to make sure prerequisites are not causing issues. If you do not have IT installing and are not familiar with some of these settings this can seem daunting. However, usually a reinstall will fix many of the issues.
Make sure your graphics driver is the latest. Check your setup.ini file to make sure the C++ and .NET are not conflicting with what is already on your machine. Usually the log file [you can access this by typing %temp%] in your search box will tell you what the issue is. I hope this helps, just take the issues one at a time and you should come to a resolution fairly quickly.
