Autodesk Revit Architecture 2016 *Product Key* Not Working
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
6169 Aufrufe, 2 Antworten
Hi everyone,
I recently installed Revit Architecture 2016 using an educational license. When trying to activate the license for the product, it accepts the serial number but not the product key. A red message comes up saying, "Please correct information highlighted below", and then a red arrow comes up beside the product key that says, "The product key entered is not valid. Verify and re-enter it".
I only generated this serial number and product key combination this week and it is a combination for Revit Architecture 2016, being used for activation of Revit Architecture 2016.
Would appreciate any help on this as I'm not sure what could be causing this error.
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
Alexander.Rivilis
als Antwort auf: Anonymous
Product keys: https://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/find-ser...
Autodesk Revit Architecture 2016:  240H1
Autodesk Revit 2016 829H1
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Nachricht 3 von 3
als Antwort auf: Alexander.Rivilis
Thank you. For some reason the product key that was generated gave me the one for Revit 2016 instead of Revit Architecture 2016.
