Hello , I just installed the new updated Revit version 2020.1 . It is perfectly working, but I ‘ve notice a new app that was installed at the same time. It is the Autodesk Model Checker Configurator for Revit.
I have never use that before. Can any one explain to me what can I do with that or how it works?
Thank you, appreciate any information.
Joshua
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
… that app it’s been around for some time… since 2017
… you can get specific information in this model checker configurator web site
… it is pretty practical once you get the idea
… or here in autodesk model-checker-for-revit-configure-check-your-model
… once you load your model and all info.
…. it will keep checking that everything is in order
… the complete you-tube tutorial model checker for revit
…. here is the latest version
…BIM Interoperability Tools v7.1.7159.0 for Revit 2020
…. Update (9.6MB). Released Aug 26, 2019
… BIMInteroperabilityTools 7 1 7159 0 2020
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
