Hello! I was wondering if all the Autodesk Material Libraries (low, medium and library 2021) are necessary. Mostly because my C driver is running out of memory and I wanted to only keep Autodesk Material Library 2021 and erase 'Autodesk Material Library Low Resolution 2021' and 'Autodesk Material Library medium Resolution 2021'.
I doubt that the Higher Resolution Textures are impacting Memory, but the Core Content has always included the Low Resolution Textures. That is, in the past you needed to install Advanced Materials separately. Keep in mind, those are used by all Autodesk software, so I wouldn't delete them.
Hello
Have a look at this link for Material library.
you can always install it later if you like..
so as of now, if you want to get rid of high resolution library, JPGs etc you can do it.
but as @barthbradley said, keep it, and you just need more Hard drive space for your Revit task.
try cleaning up other stuffs instead, move any heavy files out in portable drive, disk cleanup, uninstall any other heavy softwares which you are not using etc.
cheers.
