Hello, I have just installed the student version of Revit 2016, and once I started the program this message came up. I waited 30 minutes and it still showed the same message, then I decided to force quit the program and start it again, the same problem occurred. I went to the control panel and clicked repair/reinstall. Same problem happened again. I decided to uninstall the program and then install again, the same message popped up.
Here's a screenshot of the message.
If it's relevant information, I use a macbook pro retina display with bootcamp installed windows 10, 64-bit, 128 GB.
That's connecting to Autodesk's server to check its license. Make sure you have an internet connection and try to wait it finish
hello, try to switch off all your anti virus program and firewall and reinstall again, see if helps. thanks
i turned off the firewall and all anti virus programs, but it still shows the same thing
hello, you must have direct connection to internet and don't use wifi. delete all your files c:\temp folder those cannot delete just skip and see if helps. set your computer to administrator privileges. thanks
