Autodesk Interoperability Tools Error
Mark.Ackerley
Mark.Ackerley
Hi All!
We are receiving the following error on 1 project only, other projects are fine, different users get the same message.
"Binding the parameter to the category Analytical Foundation Slabs is not allowed.  A transaction or sub-transaction was opened but not closed. All changes to the active document made by External Command will be discarded."
The error occurs when the 'Setup Project' is opened and Saved, even just with default settings.
I don't appear to have control to avoid the attempted binding.  Even if the 'Select' dialogue has everything set to None, it still tries and fails.  Systematically working through un-selecting has no effect.
This is in Revit 2023.1.5.  Interop Tools 9.2.2, I would post to a specific Interop Forum if I could see one.  There also doesn't appear to be a specific Interop Support location, the link on the web page goes to a generic page.
Any assistance or pointers as to where to get assistance would be gratefully received.
Mark
Mark.Ackerley
We have a solution, we need to remove analytical from the parameter associations in Manage Parameters.  You can't see that specific parameter, but if you remove the other Analytic ones, it goes.  We used python to identify and remove in bulk.
handjonathan
Thanks for the update @Mark.Ackerley Glad you got it sorted.
Jonathan Hand
Technical Marketing Manager | Construction
