Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
Flow Design is only supported in Revit 2014 & 2015. If you want to run an analysis on your 2016 Revit models then you should export out an ACIS file and read that into Flow Design directly.
See similar post HERE
Flow Design supports these file types
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
