Autodesk Enhanced DWG Exporter for Revit
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1521 Aufrufe, 3 Antworten
I am testing the DWG Premium export plugin for Revit, which should significantly improve the quality of the DWG export from Revit.
  However, I notice a Revit crash when I want to adjust the Layer General Mappings. To be more precise, Revit mill for very long minutes (I stop the software so much it's long) when I set these famous matches.
Do you have the same problem?
  If so, have you managed to fix it?
Thank you in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
Which version of Revit and windows are you using?
Did the crash occur after you've installed this extension? Is this specific to a user/ machine/ model?
Do you get any error messages? If so, please send me the screenshot, it will help me troubleshoot further.
From your description it seems you have a Revit performance issue also.
Can you confirm if you have the latest updates insalled from your desktop app for your Revit version?
Let me know if you have any questions on updates.
Nachricht 3 von 4
Viveka_CD
@Anonymous
Providing a link for the community seeking Autodesk enhanced dwg exporter for revit
and FAQs on installation of the tool
I haven't heard back from you in a while and if you have additional questions please post on this thread.
Nachricht 4 von 4
krozturk
als Antwort auf: Viveka_CD
Hello,I have problem about finding Enhanced DWG export options for Revit plugin.
Im using Revit 2021,can you please share the link if it is avaliable or suggest the plugin which is making the same process?
@borakin1
