**Reposting from Revit API Forum**
Hopefully this is a simple interface one.
In Revit 2022 I have had 8 projects for a few months. I just added a 9th today. When I went to check on the project and make sure it uploaded fine I cannot see the added project because the entire list is not visible...
Is there a fix for this? Is there a way to move down the list? Scrolling/hovering/clicking does not move the list
Hi, this has been registered previously and there is a Knowledge Base article on resolutions and workarounds.
Some BIM 360 projects do not appear and the scroll bar is missing in Revit (autodesk.com)
I hope this helps
It appears to have needed at least 12 hours to update from ACC/BIM360 down to Revit. My issue was specifically in 2022 and now there is no issue - it has the scroll bar now and I can see the new projects
