Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Autodesk Assistant for Revit
juri_pelkonenE4XP5
juri_pelkonenE4XP5
Hi
Is Autodesk Assistant availlable for Revit, and if so, how?
Sahay_R
The Autodesk Assistant is currently in Tech Preview and is only available for Standard or Premium subscription customers using English Revit. You must access the product Help from within Revit to use the Autodesk Assistant.
More info -
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-463377CA-4C20-472F-A13D-78403DFE2E5A
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
juri_pelkonenE4XP5
Hi @Sahay_R, thanks for your quick reply!
What I was after was Autodesk Assistant that is embeddeb in Revit itself. I saw this feature in AU2025, but after frantic searching I'm beginning to believe this is not available yet. Everything I've come up so far eventually leads to the same page you just shared with me.
