Autodesk Access (2025) has been freezing Windows 11 taskbar and applications other than Revit that I have open.
I resolved it by disabling in startup.
I've tested this by running Access after a startup.
it's not an ideal solution as you might need Access for certain tasks related to Autodesk software. Have you tried reaching out to Autodesk's support team regarding this issue?
You could also try :
Right-click on the Autodesk Access executable file or shortcut. Select "Properties" from the context menu. In the Properties window, navigate to the "Compatibility" tab. Check the box labeled "Run this program in compatibility mode for:" From the dropdown menu, choose a previous version of Windows that you know was compatible with Autodesk Access (e.g., Windows 10). Apply the changes by clicking "Apply" and then "OK".
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
for me there is no Windows 10 in the combability options, I only have Windows Vista, Windows 7 and Windows 8.
Do you know any other options to fix this issue?
Thanks in advance!
