AutoCAD "Quick View Drawing" for Revit
3 ANTWORTEN 3
Nachricht 1 von 4
Sandervp
497 Aufrufe, 3 Antworten
Hello everybody,
Does anyone knows if there is a function or an add-in which shows small views off all your open windows?
A function like "Quick view drawing" from AutoCAD for Revit 2017 or higher?
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
coffeejeanpaul
als Antwort auf: Sandervp
See attached if this is what you referring to ?
Revit 2019 have window tabs at the top that indicates all the drawings that are open with there names.
Hope it helsp
Nachricht 3 von 4
The 'Tile Views' function is close to that.  After that you can 'Tab views' to get the full screen again.
Nachricht 4 von 4
indiana_j0nes
Something like a hover over and quick view I havent seen yet, or maybe there is one which I am unaware of.
What I can think top of my mind is. Window Tile WT command
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
and then TW to switch back to Tab Views.
So again. WT and then TW, simple right?
hope that helps to some extent.
Cheers, K
Kunal Tuljaram Gaidhankar
