why does this autocad dwg inserted into a Revit project appear like below?
this is the actual dwg.
Go into your object styles menu, and reduce the lineweights of all of the lines in that import.
I guess you are asking the same question as this
https://forums.autodesk.com/t5/revit-architecture-forum/autocad-file-insert/td-p/12191865
