Australian Default Architectural Template File
jansanmedia
jansanmedia
Where can I locate an Australian Generic Architectural template for Revit 2023?  After installation, it doesn't seem to be in my list of choices for template files. Can I access/download it from Autodesk?
RDAOU
@jansanmedia
Its been a while but as I recall, content libraries are downloaded and installed separately. You can do that from account management or see Autodesk link below...Australia should be under the International Section
Autodesk Revit 2023 Content
jansanmedia
Thanks for the reply, RDAOU. I have the Australia Content Library already, but I don't see any project templates in it, only Family Templates. In the "Templates" directory in a similar location there are a range of default templates for other languages and in the English subfolder, templates for the US, Canada, GBRENU, etc. I would have thought that would be the location for a Australia/New Zealand template version?
RDAOU
@jansanmedia
They are two separate folders for families and project templates....The project templates should be under the following path C:\ProgramData\Autodesk\RVT 2023\Templates\English\Australia
jansanmedia
Thanks.  I downloaded the exe from the content link and ran it and this time it did include an Australia folder in the project templates folder. One more question:  is the defaultAUSENU one what was previously referred to as the 'Architectural' template? It seems evident considering all the others are quite specifically targeted, but I've seen many blogs and other soruces suggesting to use the 'Architectural' template, though I haven't seen a template file with that included in the filename anywhere.
jessica_littleyH384J
Community Visitor
Community Visitor
I have the same issue where there is no specific file named Architectural...
