Attaching Within Groups
Hello all,
I'm curious if the latest Revit release better accommodates attaching walls to roofs within groups. This has been a finicky issue. This can be done in individual instances, however when one group is swapped out for another and then swapped back again, the walls become detached (in some cases it works fine and reverts back to the attached version, there seems to be no rhyme or reason why it works in some group instances and not others). Has this or will this be addressed in future releases? (I'm currently using 2017)
cbcarch
I have not used Revit 2019 yet--I have not seen any changes in Revit 2018 for this behavior.
You might try to use Reference Planes to attach walls to instead of floors or roofs inside of Groups.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
