Attaching wall to roof, till certain point
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
cadedu22
736 Aufrufe, 5 Antworten
How can I attach wall to roof, but to certain points?
As shown in this image?
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: cadedu22
Revit does this from time to time. Set the wall height top constraint to roof and the wall should be able to attached to the U/S Roof. However what I find odd is in Revit 2022, even if you set the wall to level 3, it will attached it to the roof.
Nachricht 3 von 6
Create a solid mass, join geometry it with the wall, turn off mass category.
Nachricht 4 von 6
You can draw a Ref. Plane in Elevation and Attach Top of Walls to that RP, instead of the Roof.  Or, you can Edit and Modify the Wall Profile Sketch Boundary.
Nachricht 5 von 6
RDAOU
@cadedu22
Attach it to the roof as per image 1 and create an opening by face...or use an in-place void to cut the wall
Nachricht 6 von 6
cadedu22
@ToanDN
@barthbradley
@RDAOU
Thanks all solutions works, best one is with simple trim "Modify the Wall Profile Sketch Boundary" as it's not creating hidden elements.
@syman2000  No idea what you mean by your solution, I didn't get it. Thanks for effort tho.
