Good morning.
I would like to know if it is possible to change the configuration of linking walls with floors.
I explain myself, in the notice of;
Would you like walls that go up to this floor´s level to attach to is bottom?
I hit Attach and don't show this message again.
Is it possible to change that setting or make the message show again?
Thank you
Attached walls to a floor in a link? If both are in the link then you can open the link to do it.
Are you saying you are trying to attach to a link? You can't. You could draw a Ref. Plane and attach to that though.
Open the folder C:\Users \<user name>\AppData\Roaming\Autodesk\Revit\<program name and version>. Find the Revit.ini file. Change the "TaskDialog_Wall_Attach_To_Floor" parameter.
In 2021 Revit there are more options for TaskDialog
1 — do not show the dialog box,
0 — show the dialog box,
1001 — the window is not shown, but "Yes" is automatically selected, for example, a window about attaching walls to roofs will not appear, but the walls will join.
1002 — the window is not shown, but "No" is automatically selected.
This way we can return the dialog boxes and work normally.
