I tried to have aclean cut between the wall and the roof but couldn't do it. Is there a way to do it simply?
Gelöst! Gehe zur Lösung
Gelöst von artejon. Gehe zur Lösung
In case 2 where the wall is not attached, try join geometry.
Thank you for your post. In this case, the join geometry tool can be leveraged at first glance, but also the wall instance looks to be potentially split. Is that correct? If so, have you joined the two walls and then join to roof, and if so does this still persist? If so, please attach a copy of your model for the community to review. We are happy to help moving forward where applicable.
For additional reference, I have include information on the join geometry functionality to review. I hope this helps.
Join Geometry: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
These are the layers of the same wall. If i attach on the coarse detail level it looks ok, on the other two detail levels it is not.
No, it didn't work to joint the wall and the roof.
I attached the roof and the wall.
Thank you!
If you edit type of a roof and change function of 'Generell, icke-bärande' layer to 'Structure [1]' then your wall will be attached to the underside of a roof.
