Hello
As a practice before testing real conception I tried a simple case of gridshell structure made out of a pattern based family.
But I'm facing two small issues
Does anyone have an idea of how to do such thing
Thank you in advance !
Can't attach spline point to toposurface
Surface cutting trough ground
Gelöst! Gehe zur Lösung
Gelöst von FAIR59. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Oh, well ... I didn't know I could make/insert topo while creating an in situ mass
, and after looking I don't even know how as the topo ribbon doesn't appear in mass sketching mode
I'm not talking about creating a Revit Toposurface while inside of Mass editing environment. I talking about importing CAD into the Mass editing environment. You can export an existing Revit Topourface to CAD, and import it back into the Mass editing environment. You can then apply Curtain Wall Systems, Walls and Roofs to the faces of the "Toposurface" Mass outside of the Mass editing environment.
As you noticed, you can't place a spline directly onto a TopoSurface. You need a intermediary Element.
Planting Families have a TopoSurface as host, and "follow" the surface.
Didn't taught of Planting familiies ... It's a wonderful tips ! Neither did I for importing the CAD inside the masse editor !
Thank you very much ! ![]()
