Hey Revitiers
I have this circular ramp, half circle/spiral, which is supported by columns from below. Alll good, I modeled the ramp then placed the columns on the 0 level up 4m high each along the projected center line of the ramp then I got stuck.
How can I attach those columns to the ramp so that they get increasing height as the ramp ascends?!
Thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Model the ramp using a swept blend...and make sure to select a category which allows columns or walls to atch to it. In this case "floor"
if you used the ramp tool..go to wireframe mode the model a new one on top of it using the wireframe to pick path, top and bottom profiles. Once done delete the old ramp.
now the columns attach and u can as well join it to the floors for a nicer detail
cheers
@JasonLLINDNER couldnt edit previous post, but realizing that swept blends can be a hassle for some when it comes to spiral ramps, here is another method Using .SAT export and then import for converting the ramp (done by tool) into an In-place floor element to which you can attach stuff and reinforce it later if you wish. Both the above and this method are applicable though.
Hope this helps...cheers
@RDAOU hello, my idol, just want to check with you, in this method of your screencast - ramp to floor, is there a way to edit the floor size? thank you my friend.
