Attach architecture walls to structural elements on linked file
2 ANTWORTEN 2
Nachricht 1 von 3
ayman_tamimi
169 Aufrufe, 2 Antworten
Hello everyone, hope you all doing well,
we're working on a file in which each discipline has its own file, so we are linking our files together,
so my question is, what is the best practice that can let me attach my arch walls, to the structural beam?
is it by doing them manually? or something else.
thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: ayman_tamimi
Change the height of the Parent Project Walls. If you want to attach using the Attach Top/Base tool, draw a Reference Plane at the Beam and select that RP as the target.
Nachricht 3 von 3
hmunsell
https://forums.autodesk.com/t5/revit-architecture-forum/joining-walls-in-two-linked-models/td-p/1141...
Howard Munsell
