I have this issue that when i go to the Load Family command to get sort of component to my project
it is stuck at the last place,
(the main rout is set at the library path at option)
What is the reason for this ?
thanks,
benny
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
It's suppose to lead to the default route that set on file location tab (places) for example US Metric,
just like it is working at revit 2018.
Thank you,
Benny.
Thank you,
Benny.
No they changed the behavior in Revit 2019. Make use of the left side panel shortcuts too get to your library and other frequently used folders more quickly.
