Is there a way to associate the parameters of multiple nested families to one parameter in the host family? For instance I'm attempting to create a master millwork family with multiple nested fronts (1 door, 2 door, 1 drawer and a door, 3 drawers, etc) where the user could change the type of millwork from a drop down list in the type properties and I want them to be able to adjust the drawer height in the type properties, however the problem is that it appears that i can only associate the families to just one nested family at a time.
There are two parts and they are independent:
1. A dropdown to select a nested family type to be associate with a master family type (2 drawers, 3 drawers, etc...): Create a label (Family Type parameter) in the master family to get the dropdown list.
2. Changing dimension parameters for certain parts of the nested families:
- Create the dimensions as instance parameters in the nested families
- You can change these dimensions in the master family directly. if you want to further be able to change these nested dimensions in project, then add instance parameters in the master family and associate nested dimension parameters with them
Thanks, That's what I did but it was still not working. I changed the name of the instance parameter that controls the drawer height to match the other nested families and it appears to be working.
