Assigning Materials to Imported SAT Files in a Family
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
623 Aufrufe, 12 Antworten
I'm having trouble establishing a workflow for the proper way to assign two different materials to a toilet I've created in Rhino but would like to import into Revit.  I'm including a couple of my working files below in the hope this will help illustrate what I'm dealing with. Specifically I would like the button to be one material parameter and the body to be another material parameter when ultimately brought into Revit.  Any help is greatly appreciated.
Mike
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
I believe you need to export from Rhino to DWG with layers in order to assign materials via Imported Object styles in Revit.
Nachricht 3 von 13
Corsten.Au
Hi
go to object styles and assign material..
Cheers
Corsten
Building Designer
Nachricht 4 von 13
als Antwort auf: Corsten.Au
How does that work in project?  What if another SAT plumbing family needs to have a different material?
Nachricht 5 von 13
@Anonymous: You know; if it were my project....I'd download a Revit Family from the Manufacturer, or find one comparable to use. After all, It's a toilet; how unique can it be?
Just saying.
Nachricht 6 von 13
Corsten.Au
als Antwort auf: ToanDN
lot of ways and work around to fix that .. ( shared parameters, etc )
I would just paint it...
I would say just create a simple family.. probably using SAT file as a mass and
create a regular Plumbing family to keep things simple..
there are always work around...but one or two steps are fine..cause
beyond that it opens up Pandora of problems and legacy issues..
Cheers!
Corsten
Building Designer
Nachricht 7 von 13
Yes, that was my concern.
Nachricht 8 von 13
als Antwort auf: barthbradley
If I hadn't researched this one as much as I had I would totally agree.  At the risk of sounding like a very nerdy architect I will just say this manufacturer doesn't have a revit file and they represent a new product here in California that is being used a lot.  Great flush score (I had never heard of this until a few years ago).  Reasonable price.  Good Water conservation.  So hard to find a good toilet  :).  When I do, I like to use it.  I'm planning on specing this on many projects.
Nachricht 9 von 13
Cool!  How did you get it painted like that?  I tried it and wasn't able to get the individual faces to paint.  I'm not sure I understand how shared parameters lets you do this.  Could you elaborate?
Nachricht 10 von 13
Corsten.Au
Shared parameters would actually complicate the situation... I am not gonna explain that now
cause it will be a workaround which would take more time than actually creating a simple family.
moreover if someone new works on the project and they don't know how shared parameters works
then thats next level of complicacy..
Hope your original problem is solved..
read this if you are curious..
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
cheers
Corsten
Building Designer
Nachricht 11 von 13
I'm somewhat familiar with shared parameters.  Somewhat familiar with Dynamo.  Would you mind telling me what kind of family type you painted that toilet in.  Were you in a plumbing family or did you create a mass family or something else.  Did you somehow get it exploded?  Any help is appreciated.  I wonder if I should just try and build this thing in Revit.  Seems pretty difficult.
Nachricht 12 von 13
Corsten.Au
It was same family which you uploaded..
I have created some material and painted it..
see the attached file..
Cheers
Corsten
Building Designer
Nachricht 13 von 13
Ah, I'm still on 2017.  I think that might be the issue.  I've heard some things about sat import functionality improving...think that might be the difference?
Thank you for your help.
Mike
