Assigning Curtain walls to extrusion
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
P_a_adedayo
409 Aufrufe, 4 Antworten
Hi, i have made an extrusion but i want to assign curtain wall material to it but i can't find the option anywhere, it allows me assign glass as a material but not the curtain wall itself. when i apply Glass material, it doesnt allow to add curtain grids and others. i'm trying to make an aluminum cladding out of the curtain wall and the grids but it's not working cause it's an extrusion not a mass, is there a way around without having to start over... Thank you
4 ANTWORTEN 4
Nachricht 2 von 5
constantin.stroescu
als Antwort auf: P_a_adedayo
Is this what you want?
Constantin Stroescu
Nachricht 3 von 5
Yes you can create Curtain System by face and pick the surfaces of the extrusion.
Nachricht 4 von 5
P_a_adedayo
als Antwort auf: constantin.stroescu
Ohhh, i see my mistake, i didn't select generic model when in the model in place option, i just tapped okay twice and made the extrusion. that's probably why it's not working. Thank you for this.
Nachricht 5 von 5
P_a_adedayo
als Antwort auf: ToanDN
Yeah, i 'll model it with the generic model option and try again, thank youu
