assign view filter to multiple views at once
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jnoordzij
4408 Aufrufe, 5 Antworten
is it possible to assign a view filter to multiple views at once? (without using a template)
Thanks in advance.
JN
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jnoordzij
Create a template that only has the View Filters box ticked, add the Filters, and assign it to Views. Nothing else will change to the Views except for the added filter. You can remove the template afterward and the filters remain in the views.
Nachricht 3 von 6
jnoordzij
als Antwort auf: ToanDN
Not the answer i was hoping for but thanks!
Nachricht 4 von 6
denisyukJ
Dear, ToanDN
Do you know a solution how to insert additional view filters to already existed? Sure, for the batch of views not for a single one. I only found a topic on dynamo forum but its not solved.
Nachricht 5 von 6
als Antwort auf: denisyukJ
Create a view template and untick every box except View Filters, add the filters to the template and assign the template to multiple views. After that you can remove the template from the views.
Nachricht 6 von 6
denisyukJ
But it will remove already existed files to the new one, isnt it? I want to add new filters to already existed (existed filters are not a same in the views).
